Spider Crap on Vinyl
Re: Spider Crap on Vinyl
Any suggestions for removing spider crap from Sunbrella boat cover. Unfortunately I had a custom cover made with a wide yellow stripe down the middle. Bad idea. The cover is on the boat year round in a boat stall. First year I scrubed and power washed the stains out....along with the water proofing. Now I know to be more carefull but the stains remain.
Social Distortion
Scrubbing bubbles works well for us before shows and we also use a cleaner called MOX. The mox works well on vinyl but leaves a film on any fiberglass or chrome.
Marineclean, your the MAN! I took your recomendation of the Lysol and the pads. After I did my interior with your trick, I went over it with a couple of Magic Erasers and then sprayed 303 on everything. My interior hasn't looked this good in years. Guys, it works!! I'm ready for Poker Run season.
You will think I have lost my mind, but had an interior guy show me this. Get one rag wet with water ready for quick cleanup, then use mineral sprits on the stain with a rag. Just be sure to quickly clean up with water and not let it dry. Then condition. Magic eraser does wonders when wetted with a commercial vinyl cleaner instead of water.
Sorry back to topic...........
I have this spray cleaner from work called korkay cleaner and captain mikes boat cleaner.both work very well with magic eraser.problem is when you do 1 spot you have to do the whole thing
