Go Back   Offshoreonly.com > Technical > Fiberglass and Paint
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 11-28-2006, 08:49 PM   #41
Charter Member #232
Audiofn's Avatar
1979 Formula 302
Re: Transom rot! Looks like a long winter for me!
You can get the DB glass with or with out the matt.
God is my Co-Pilot..... but I hit a mountain and had to eat him.
Audiofn is offline   Reply With Quote
Old 11-29-2006, 08:45 AM   #42
Bob Teague for President!
offshoreratboy's Avatar
1988 Formula 357 SR1
Quote:
Originally Posted by offshore ginger
OFFSHORERAT BOY cool dude that you are going to use west system . i got my first experience working ,with fiberglass & epoxy , over thirty years ago building windmills for them . i still to this day use there product and so does skater . i have to say that thay make a resin , & hardner, which is called there tropical blend . i also can honestly say thay if you want a a lot more work time , and not have to work as fast you might want to consider this . i use this alot because the cure time is so much slower . just my 2 cents G. .G .
Thanks guy... I really don't need any more time than what I get out of the slow hardner but will consider it when I put the chop mat in that goes accross all of the wood sections (3 of them). thanks...
Joe
offshoreratboy is offline   Reply With Quote
Sponsored Links
Old 11-29-2006, 12:42 PM   #43
Ted was very helpful thanks again for the refferal. Great guy had all the answers for me on the epoxy. You guys have provided all the rest...
Joe
Old 12-01-2006, 10:15 PM   #44
Well...this thing is kick'n my azz! I got the second layer of glass mat in. First I put one layer of 6 oz. cloth and two coats of epoxy. sanded the fisrt coat with 80 grit and then put on the second. Then I cut the wing sections and epoxied them in and put a layer of 6 oz. Then I sanded and made some nice fillets at the bottom and around the stringers. Tonight I put in a layer of chop glass matt. That sucked up a huge amount of epoxy but once I got in down and rolled out the folds it looks great. I plan on one more layer of 6 oz. cloth and one more of the chop, with two coats of epoxy over each layer. Sure glad I don't do this stuff for a living. My back and knees are kill'n me.
More pics to come...
Joe
Old 12-02-2006, 12:09 PM   #45
personnaly boatless ...
jeff32's Avatar
personnaly boatless for now...
I love your brand new look!
jeff32 is offline   Reply With Quote
Old 12-02-2006, 04:18 PM   #46
Queenie's Avatar
Told you it would be labor intensive!
Looks good Joey! Get that done and you can start on the fairing.
Rob
Queenie is offline   Reply With Quote
Old 12-03-2006, 12:05 AM   #47
No Fairing this year Rob, I think I got enough to do...Stop by the shop and I'll take you for an inspection tour
Joe
Old 12-04-2006, 11:26 AM   #48
Okay...I got the transom done! YAHOO! Took about 75 hours all together. I wish the rest of the work was done. Now I must address the other end...YES you guessed it, the fuel tank bulk head is shot similar to offthefront's boat. There is no real attempt to make this part water proof on any boat. Vertually every boat that I work on has this problem if it is 15-20 years old. They don't even cover it completely with gel let alone glass. I will be cutting it all out tonight but you can see by the pictures what I'm gonna find. The big center stringer and port stringer is good but the starbord stringer has a bad spot... All because of 5 or 6 strap screws that were screwed in at the base of the sringer where water collects. I'm certain I'll have some ugly pics in the next day or two...
Joe
Old 12-04-2006, 03:01 PM   #49
Mike
offthefront's Avatar
353 with Prochargers
What happened on my 311 was the side stringers sucked up the water from the foward bulkhead ....your right .. the bulkhead was a total loss ........m
353 Formula 4 Sale 75K 904 422 4806
offthefront is offline   Reply With Quote
Old 12-04-2006, 09:51 PM   #50
Charter Member #232
Audiofn's Avatar
1979 Formula 302
You want a picture of what is to come? Just call me Mr. Doom and Gloom
File Type: jpg 63 Stringers all glassed in (Small).jpg (54.5 KB, 130 views)
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Mistress Transom Rot justice Cigarette 37 06-11-2008 06:24 AM
Will oil in transom cause rot or not? phughes69 General Q & A 1 08-10-2005 06:34 AM
Question about transom rot Courtholl Pantera 0 08-08-2005 10:59 AM
Winter Is Too Long performancemary General Q & A 0 02-11-2005 11:01 PM
Transom rot... cowisl General Q & A 5 04-29-2004 04:47 PM
Search Engine Optimization by vBSEO 3.2.0
