how to blend in ...........
When i paint a area how due i blend in the place where the tape line is..................for example there is a place in the front of my boat by the hook were the last guy hit the trailer with it,there is no seem to tape to do it has to be blended how due i due it................
Re: how to blend in ...........
Wet sand the area with 1500 and spray to blend color. Wet sand with 1500 when dry approx. 16 hours later. Polish with a fine cutting compound. Don't let the paint cure too long or it will be hard to polish-blend.
I color sanded through in a few spots, I am NOT using base coat clear coat. I am using a single stage polyurathane, can I make a good blend and how do I do it? I would like to go ahead and finish color sanding to 1500 and buff, then go back and sand the few spots and blend in. Best how to info would help me out...
you want to be very careful on the blend area when you spray. Trick is to not fan out the blend line. Stop the gun/color abruptly at the end of each pass and use a slightly thinner final coat and make the last coat just slightly larger than the previous/main coats . Than mist on an edge blender solvent. its actually kinda tricky but not terribly difficult. Try not to buff the edge any more than you hafta to bring out the gloss usually i hit the edge lightly with 1500 than 3000 than buff.
this is a process for repair in the middle of large areas where it is not feasible to blend to an edge.
as js said dont let the final coat go to long or buffing can be difficult. 16 hours is good and no more than about 48
08 OPA High Points Champion
its basically a slow drying solvent that helps th edge lay down better. it is available in a aerosol can and really is the key to blending the line in. Gimmie a call when ya can hope the project is going better for ya.
