carnuba wax???
So if gel coat needs to breathe, what happens when you clear coat over it like most of todays new paint jobs? Does it still breathe thru the clear coat?
My boat did turn quite yellow over a 3-4 year period. Had it professionally detailed and it is back to white again! I was using Star Brite and Meguiars. Don't what to use, I can't afford to have it professinally done every couple of years.
Would throw up the same question in my mind. I've always understood that gel coat is a somewhat porous material that needs to be sealed,in some fashion, to protect it. Being porous it can, over time, pick up and hold some dirt, for lack of a more techical term, and the result can be discoloration of some sort. IE> bottom stains that require agressive cleaning such as acid bottom wash to remove. I have never heard that it needs to be alowed to breath. That being the case, no manufacturer would apply any form of paint, by doing so it would make them responsible for any resulting damage. Perhaps Marieclean has some info on this that we are unaware of, maybe he could share that here.
On my own boats, always inside for storage and boathouse kept in season, I've always found that a solid/regular program of cleaning, a once a year buff with 3M Finesse-it followed by a good quality wax gets rid of/keeps the crud from biulding up/collecting. If you want that perfect shine there are no short cuts, at least that I have ever found, and I've tried most every wonder product out there.
From our research;
Carnauba acts like icing on a cake. It seems to clog the surface and actually produce a layer that, when mixed with the sun, dries the surface out and causes oxidation and chalking. Clear is not having oxidation problems as bad as gel, but certain waxes containg carnauba are still producing premature oxidation.
Scre It,
This is what we have found in our own research when working with different products. Please let me know if this helps.
Donnie
FYI; Star Brite with PTEF contains (flammability #2)
15% Petroleum Distillates
20% Kerosene
5% Alcohol
and those are just a few of the ingredients
So Please, No smoking or open flames around the boat.
Please try my Leverage Polish when you get a chance.
Donnie
