carnuba wax???
#31
Hers a question for ya marine clean...............Before i say anything i am going to buy your products from fred......But i need to know what to buy, with that being said i have a new paint job....Base coat urathane and 3 coats of ppg clear......After i wet sand what steps of your products due i go through,and no i am not looking to save steps i just want it perfect and i always like to be the guy that tries new things.......I want to be the guy that says try this sh%t it is the best...........
Not sure how long ago you painted it but if you are going to sand and buff it really needs to be done within a day or so after painting. any longer and the finish it way to hard. it can be done but its about 5 times the work as if it was done immediatly after it was painted. if you want to bring out a shine at this point i would not wetsand it, dry sand with a DA. you will need to step through several grits to tackle it though. start with 3M's 1000 than 1500 than Trizak3000 ( the 3000 you do wet) also make sure to use an intermidiate pad on the DA with the 1000 and 1500. Polish it with 3M's imperial polishing compound an a white foam pad.
08 OPA High Points Champion
