Go Back   Offshoreonly.com > Technical > Fiberglass and Paint
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 02-06-2008, 08:53 PM   #41
Charter Member #232
Audiofn's Avatar
1979 Formula 302
Quote:
Originally Posted by Sean H View Post
i would of used coosa colored shelf paper...
Some how I do not think that Dave is EVER going to live that one down
God is my Co-Pilot..... but I hit a mountain and had to eat him.
Audiofn is offline   Reply With Quote
Old 02-06-2008, 08:54 PM   #42
justice's Avatar
1978 35' Cigarette Mistress
What do you backfill with in the gaps, cabosil?Should I lay my first sheet of glass on transom let dry and sand,lay a sheet of glass on first piece of plywood and let dry and sand,epoxy and tab to sides of hull?
justice is offline   Reply With Quote
Sponsored Links
Old 02-06-2008, 09:10 PM   #43
justice's Avatar
Yeah I puckered up a little when I made that cut!!! Back area of deck needed paint anyway!I think I can grind the edges at 45 angles set the piece back in and glass it from the inside as from factory.Fill the topside 45 degree gap with 4 layers of 2" glass,a little kitty hair,sand her out and see what I have.I will keep posted with pics.Had to pull a ICEMAN and just do it!!!
Old 02-06-2008, 09:39 PM   #44
Charter Member #232
Audiofn's Avatar
1979 Formula 302
Yes use Cab. to fill in the gaps. The Cab. is also a great thing to use in the corners. Glass does not like to go around corners so you radius them with the Cab.. Cab. also sticks like diaria on a wool blanket so it holds the glass down in the corners for you.
I would use 24 grit to to grind everything out. Then wet the transom with resin, lay glass on there, wet the glass, wet the plywood and install the first piece. Then do that again with the second piece of plywood all at once. Then bolt it all in place. The other way to do it is to mix a past with Cab. and trowle it in there with a notch trowle. I would only do this at the transom not between the two layers. You want to do the layers of plywood all in one shot to keep as much chemical bonding as possible.
Old 02-09-2008, 05:25 PM   #45
justice's Avatar
OK guys,ordering materials from USCOMPOSITES monday.Think the best wayto go is all epoxy with
binderless stitched mat as Dave suggested,everyone agree?
Ordering
5 gallons of 635 epoxy with medium hardner
14 yards of binderless stitched mat
cabisol
Leave anything out?
Old 02-09-2008, 06:07 PM   #46
Neno the mind boggler
glassdave's Avatar
Batboat, 38 Donzi ZX, 16 Sidewinder, 10' Zodiac and a ScarabIII
keep in mind those were two different laminates we discussed
The binderless mat is also called epoxy mat from UScomposites (pn# fg-em10550). it is 1.5 ounce continuous strand mat stiched together with no binder. you should need about 8 yards with the triple ply transom. This is what you will use as the first layer and inbetween each layer of wood.
The Bi-ax is 1708 Nytex fabric, it is 17oz double bias fiberglass cloth stiched to a binderless .75oz mat. This is what everything will be encapsulated in. I use two layers on everything and at least two more on all joints. Gonna need atleast 10 to 12 yards of this.
both of them are only about $6.50 a yard so having a few extra yards is advisable.
Give me a call when you get closer to doing it and i'll try and give you a few tips for laying up with epoxy, there are a few tricks 419-461-1484
08 OPA High Points Champion
glassdave is offline   Reply With Quote
Old 02-09-2008, 07:29 PM   #47
justice's Avatar
OK,epoxy and binderless stitched for in between layers of wood,then biax and poly to be used on final piece of wood and to glass everything in?Thanks I will call for some much needed advice when I get started!
Old 02-10-2008, 07:08 PM   #48
glassdave's Avatar
use either poly or epoxy, one or the other not both. Poly can have curing issues when exposed to the amine blush that is associated with epoxy. 635 is an easy epoxy to use on this type of project becaust it wets out similar to a good laminating poly but has a longer working time.
Old 02-10-2008, 07:13 PM   #49
justice's Avatar
Thanks Dave will keep pics updated!!
Old 04-12-2008, 02:45 PM   #50
Justice
How did the transom replacement come out would love to see the out come. As I mite have to do the same on my Mistress !!
THONG CHASER is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Mistress Transom Rot justice Cigarette 37 06-11-2008 06:24 AM
Transom/Stringer Replacement jez350 Fiberglass and Paint 65 10-22-2007 09:41 PM
Transom replacement gone wrong jackhammer Fiberglass and Paint 55 05-28-2007 08:46 AM
Transom replacement jackhammer General Q & A 5 10-14-2004 09:46 PM
transom replacement later General Q & A 7 02-28-2003 12:53 AM
Search Engine Optimization by vBSEO 3.2.0
