| OSO Sponsor |
| OSO Sponsor |
06-16-2008, 10:51 PM
#81
26 american offshore
awsome job justice you should be proud!!
06-22-2008, 06:39 PM
#82
1978 35' Cigarette Mistress
How to repair the chips in hull?Any suggestions on new wind shield?
04-11-2009, 11:33 AM
#83
Putting her back together
He guys here are a few pics on Mistress going back together.Have port motor in and working on my new wiring this weekend.Interior is pretty much done.Trying to decide on carpet or cushions for interior walls,any ideas?Also have a MSD 6al ignition I may need help with the wiring on that.
04-11-2009, 11:35 AM
#84
Few more pics
Few more pics
04-12-2009, 09:52 PM
#85
86 34 scarab raider 2x300efis
Looking good!
04-13-2009, 11:30 AM
#86
Neno the mind boggler
Batboat, 38 Donzi ZX, 16 Sidewinder, 10' Zodiac and a ScarabIII
love the wood in the cabin, looks great.
08 OPA High Points Champion
04-13-2009, 03:22 PM
#87
more teak pics
Think the teak was as hard as the transom work!
12-22-2009, 12:04 PM
#88
1994 Baja 236 500HP
Quote:
if you choose to go with epoxy west system is pretty good stuff but is heavily marketed. It will cost a fortune and quite honestly the viscosity is a little to high to wet out very efficiently. Go to uscomposites.com and take a look at their 635 epoxy with a medium hardener. Up side of using epoxy is a longer workability for the first timer. Keep in mind if you choose to use epoxy you will have to use a binderless stitched mat as opposed to a standard ounce an a half mat that is normally used with poly, and yes you will need one layer of fiberglass between each layer of wood. Also you cannot use any type of gelcoat to brush coat the bilge, it will have to be painted.
The only fiberglass you will need is ounce and a half mat and a 1708 or 1808 bi-ax. I wouldnt bother with the roving Nytex is way easier to work with and you only need two layers.
another neat trick that really dosent cost alot is a method for putting pressure on the transom while it cures. as Chris said earlier drill through existing holes and through bolt. But for areas where there may not be an existing hole try using a few of these
http://www.harborfreight.com/cpi/cta...emnumber=43569
i use 4 of them (under $30) to aid in applying pressure in those tough areas.
Thanks for the idea Dave going to get abuout 4 of them.
12-22-2009, 01:27 PM
#89
1982 Pantera 24sport
Thanks for bringing this TTT, gonna do a transom on the Pantera in January.
01-01-2010, 04:49 AM
#90
Just a squirrel...
88 240 with a new lease on life
Quote:
Holy smokes that is a lot of teak! Looks awesome tho, came out great.
