glossy bottom paint?
Go with an ablative paint which means it chalks off as you run and is self cleaning .Put 4-5 coats on the running areas that are in the water while you are up on plane if you want to make it through the season.
Lakeside Restorations.com
Commercial Member
Yes, and they are going to be about as bright & shinny as you are going to get. Unless you use a topside paint, but then you wont have any antifouling protection.. Jamie
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
