Refinishing bottom of hull
t500 what kind of spray wax are you using? I boat in some pretty murky water if i run up any of the rivers here in lake erie and i get some pretty bad discoloration that only comes off with muriatic acid. I dont keep the boat in the water and would like to spray something on it before i put it in.
I get staining really bad here in SD. Believe it or not, you can simply buy the "Hull Cleaner" from West Marine and it works like nothing I've seen. My buddy said to spray it on and then just rinse. NO Scrubbing or even any wiping!!!! I called him on it as it sounds to easy but stuff really works. Spray it on dry, watch the yellow stain begin to run. Then when you hit it with water the hull is as white as the day you bought it. Truly has to be the most labor free solution I can think of.
Regarding the posts about the bottom and the idea of re-gelcoating??? I just took my boat in last week to have it blue printed. After lifting it completely off the trailer, we found that the boat was basically screwed. Apparently, someone re-sprayed the bottom for some reason in the past and left it a state that is far different from factory. Make sure if you re-spray that your guy knows what he's doing and that he's using straightedges etc... I have lots of area that is supposed to be sharp with aggressive angles and it took pulling the trailer out from under it to realize that all that extra gel coat turned everything into radiuses and it's not a cheap fix.
There's been a lot of discussion on this topic. I'll come back and post results if it nets me anything noticeable whether it be speed or just ride and handling. I currently have to use quite a bit of port tab when on plance. Expecting to see this change a little.
The bottom of my hull is stained. I know this has been gone over a million times but I'm trying to figure out a real solution. The bottom of my hull is no longer glossy. It's kinda chalky and becomes stained easily. Rather than acid washing it every time, I want to fix it. If I wet sand, buff, polish and wax will the gel still stain? Buffing the bottom will be a biatch so I wanna make sure it's worth it before I start.
I thought about using one of those fiberglass refinishing kits like, PolyGlow. But I've heard mixed reviews.
I boat in Lake Erie and I rack store my boat. I've never had a problem with bottom staining. I wax the bottom one time per year with 3M Cleaner Wax or 3M Restorer Wax and any minor staining comes completely off. I also wipe down the boat after each use. I've heard that Muriatic Acid works great, but once you start using it, you can never stop using it.
I boat in Lake Erie and I rack store my boat. I've never had a problem with bottom staining. I wax the bottom one time per year with 3M Cleaner Wax or 3M Restorer Wax and any minor staining comes completely off. I also wipe down the boat after each use. I've heard that Muratic Acid works great, but once you start using it, you can never stop using it.
the stains i'm talking about are more saltwater. it's actually a growth that shows as a stain.
i use a pump sprayer mixed at about 5 or 6 to one and i use that Sno-Bowl bathroom cleaner. works great. only takes a few minutes keep it wet and use a cleaning pad like the magic erasers. Dont forget to use gloves, the stuff can be harsh.
08 OPA High Points Champion
just a tip for you guys using acid on the bottom of your boats- put the acid in a plastic paint tray and use a paint roller instead of a sprayer, the acid can get on your skin and easily burn you. If you get a little bit of acid on your skin you may not even realize until you already burn.
The roller method also makes it really easy to see what you have left to do and uses less acid then spraying.
Alot of guys around here complain that after a while they cant get the bottom of thier boats clean without acid and alot of work, in those cases they get them painted and from then on its soap and water and the bottom always looks shiny and clean with no stains. If the bottom of the boat is in good condition you can save yourself some time and money and just paint right over the PROPERLY sanded gelcoat.
Here's a tip for you guys. Clean the bottom up really good, then use "Future" floor finish on it. It's an acrilic floor sealer. I have been doing this for a few years with great results. Just squirt it on a sponge, wipe it on and let it dry. Do 2 or 3 coats and it will last most of the season.
Frank
Frank
Frank
Frank
