Go Back   Offshoreonly.com > Technical > Fiberglass and Paint
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 11-30-2008, 09:02 PM   #1
Advice needed with repair
Well I was preparing a corner in my boat to re-glue a portion of the carpet that had come up when I noticed that the fiberglass cloth holding the deck to the hull was beginning to separate. I pealed of a section to get a better look and decided it was time to repair the area. Please look at the pics below and give me your thoughts.
I am pretty confident I can make this repair but wanted to get some advice.
How should I prep/clean the area?
Can I use fiberglass tape or what material should I use? (please be specific on ounce and type)
After preparing, can I just wet it out with standard epoxy and hardener or do I need to add anything else.
Thanks for the help.
http://i509.photobucket.com/albums/s...h/DSCN0280.jpg
http://i509.photobucket.com/albums/s...h/DSCN0281.jpg
Malibu97 is offline   Reply With Quote
Old 12-02-2008, 09:24 PM   #2
bottomsupboatrepair.com
Get a vacuum
and grind the old glass off. Make sure it is dry. Cut up some sqaures of material,if what we see failed then you need to go thicker. two layers of 1.5 oz mat and a layer of 10 oz triaxle or a layer of 18 oz roving.
Not to thick and cure it mild, no hot spots.
Billy
Bottoms Up is offline   Reply With Quote
Sponsored Links
Old 12-05-2008, 10:19 AM   #3
"two layers of 1.5 oz mat and a layer of 10 oz triaxle or a layer of 18 oz roving."
Can I just go with some 18oz woven roving?
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
custom pant repair needed mass sonic28 Fiberglass and Paint 3 07-14-2008 02:57 PM
Outdrive Finn Repair ...help needed FLYWITHME General Q & A 4 05-31-2006 12:07 PM
Advice on bulkhead repair fruitta55 Banana Boat 12 07-24-2005 09:59 AM
Repair 1/2" scratch in paint/clearcoat - Advice powerguy General Q & A 1 01-18-2004 07:01 PM
#IV Drive Repair needed Nut General Boating Discussion 6 03-19-2003 08:50 AM
Search Engine Optimization by vBSEO 3.2.0
