Go Back   Offshoreonly.com > Technical > Fiberglass and Paint
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 01-07-2009, 01:21 PM   #11
Rookie's Avatar
30 Scarab Panther
What about just just sanding it up to about 800-1500 grit and then clear coating it???
I have a friend that has a red boat and is always complaining about the oxidation in the texured on the deck. Took a brass brush to the textured area to remove oxidation and dirt deep inside the texture, cleaned with a degreasing agent and then clear coated it.
No matter how pretty she is, there is a guy who is sick of her S#!t
Rookie is offline   Reply With Quote
Old 01-07-2009, 03:55 PM   #12
2004 31 Formula PC and a 1988 28 Pantera
How did it look and how has it lasted?
bigboat28 is offline   Reply With Quote
Sponsored Links
Old 01-07-2009, 05:53 PM   #13
batty's Avatar
1979 32' Excalibur, 1988 38' Scarab KV
Try a product made by yachtbrite. Its called Buff magic. It works great. It comes in a paste you put it on with a paint brushthen use a high speed buffer with a wool pad to buff it in just watch it because it will make some heat on the gelcoat. follow that with a product called sea breeze ( also made by yacht brite. apply that with the same buffer but switch to a foam pad. this will polish the sides. then after that puta good coat of wax on the boat to protect it. Its alot of work but its rewarding in the end.
I used this on a wellcraft san tropez that was pink... used to be red. did the same steps and it shines like new. If you keep a good coat of wax on it it should last through the summer.
Brad
batty is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Vinyl Graphics Faded zitoracing Fiberglass and Paint 0 02-13-2007 10:07 AM
Faded Glory.... Popeyes General Boating Discussion 139 06-19-2006 04:21 PM
faded dash Boomer35 General Boating Discussion 0 12-06-2005 07:44 AM
Faded gelcoat GQ Fiberglass and Paint 14 05-09-2005 10:00 PM
How much gel-coat cand be removed before having to re-gel? Pure Energy General Boating Discussion 9 02-21-2003 08:05 AM
Search Engine Optimization by vBSEO 3.2.0
