Go Back   Offshoreonly.com > Technical > Fiberglass and Paint
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 07-14-2009, 11:58 AM   #1
Registered User
chewy1955's Avatar
1998 Top Gun
Painting aluminum Swim Platform
I am going to paint my alumnimum swim Platform cause of chips and some lifting. Seems that the paint on it is pretty tough. Can this be bead basted to clean it up? I was going to use PPG concept (purple). Any suggestions or helpful hints? Not sure how to get the "non skid" surface on the top either.
chewy1955 is offline   Reply With Quote
Old 07-14-2009, 01:04 PM   #2
32 Active Thunder
There is a good chance its powdercoated.
Use clear non skid tape.
http://www.safewaytraction.com/Flex%20Track%204100.htm
I have the 4100 series on mine. Been stuck on for 2 years and works well. The 4200 was not out yet when I got it and I may have gone with it instead of the 4100.
Griff is offline   Reply With Quote
Sponsored Links
Old 07-15-2009, 04:37 PM   #3
ROTAX454's Avatar
1998 Awesome 31 Thundercat
Quote:
I have the PPG Deltron 2000 "bill of materials" for what PPG calls Ultraviolet pearl. I wanted to paint match some deep candy purple PC parts that Exotic had done. The PPG color matches it perfectly. This is a DBC basecoat. Used the PPG Concept DBU2042 clear. Let me know if you need it. Painters Supply was my source. The color number won't do it. Must have the complete list of tints. Be ready, the DBC quart costs $$$$$$
ROTAX454 is offline   Reply With Quote
Old 07-15-2009, 04:38 PM   #4
ROTAX454's Avatar
Great tip. Been looking for the clear stuff. Thanks
Old 07-15-2009, 07:21 PM   #5
fountainfevr's Avatar
2000 Fountain Fever
Hi I have painted 2 swim platforms for Baja outlaws. They are powercoated, I had them sand blasted then sanded them with some 150 sprayed epoxy primer (DP) then applied ppg concept single stage. Remember you have 8 hours to spray aluminium it is a self healing metal.
fountainfevr is offline   Reply With Quote
Old 07-21-2009, 07:43 PM   #6
36 Outlaw
Painitng Platform
I Just got through spraying my platform with Dupont Hot Hues Amazing Grape(candy purple) 2 stage paint and it matches the purple rim gauges on my Livorsi Gauges perfect.As far as the non skid you can get the roll of Black,Grey or Clear 1" X 60 ft tape on Ebay pretty cheap.Hope this Helps:
Hank36 is offline   Reply With Quote
Old 08-24-2009, 04:35 PM   #7
Donman's Avatar
24 Python
Why not have it powdercoated ??
Just had mine done. $35 to sandblast and $185 to powdercoat.
Donman is offline   Reply With Quote
Old 08-27-2009, 01:23 PM   #8
Rob
Strip Poker 388's Avatar
Hustler 388
Hey do you like mayo on your Spam???
Strip Poker 388 is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
