Go Back  Offshoreonly.com > Technical > Fiberglass and Paint
filling in small holes on transom and outside what to use >
Old 09-01-2009, 06:05 PM
Default filling in small holes on transom and outside what to use
Im almost finished getting off the bottom paint,
so that means im pretty close to doing the paint on the boat
Im not too familiar with fiberglass so I need to need exactly what product will work for me
I want to fill in some small holes in the back of the transom, where the old swim platform was mounted to
Im putting a different setup on there that does not use the old holes
I also need to fill in a few small holes on the deck where the stock horns were
and a few small holes on the deck where the stainless rail for the front was mounted through
Im not putting the horns back in the same spot and Im not putting the railing back on in the front either I like the way the boat looks without it
so what product do you recommend to use,
this is pretty much the last thing I need to take care of before I can lay the new paint on the boat
thanks
cbellamore is offline
Old 09-01-2009, 08:09 PM
Neno the mind boggler
glassdave's Avatar
Heres a thread i did on the subject, on the third or fourth page theres some info on smaller holes. post up any questions you have and we'll get ya squared away. Hope its what your lookin for.
http://www.offshoreonly.com/forums/f...ash-holes.html
08 OPA High Points Champion
glassdave is offline
Old 09-01-2009, 09:53 PM
glassdave's Avatar
if all else fails theres always the "boat painting 101" thread . . . . entertaining if nothing else and if you dig deep ya might actually find some info on glassworkl
http://www.offshoreonly.com/forums/f...ing-101-a.html
