Go Back   Offshoreonly.com > Technical > Fiberglass and Paint
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 09-14-2009, 09:41 AM   #1
ovidation on gauge faces...
Did some searching but couldnt find exactly what I was looking for... figured a pro from around here might know... looking to remove the oxidation/water spots off of the gauges without harming the plastic face.... TIA!
-Brandon
VortechSS is offline   Reply With Quote
Old 09-14-2009, 01:35 PM   #2
CignificantOther's Avatar
38 Cigarette Top Gun/6's, 42 Cigarette Tiger/6's
Brasso polish for copper will help. Also Diamind Brite aluminum polish works. Many others also like Meguiars Plastic polish....Use heavy pressure several times with each application of product and then lighter and lighter pressure to buff back to a shine.
Go in the same direction....not circles because the heavy pressure will scratch a little and you have to buff these back out.
CignificantOther is offline   Reply With Quote
Sponsored Links
Old 09-15-2009, 11:36 PM   #3
32 Active Thunder
Try using some vinegar. Its probably not oxidation, and more than likely its hard water deposits. Use some plastic polish after and maybe a dremel with a polishing pad.
Griff is offline   Reply With Quote
Old 09-17-2009, 01:48 PM   #4
Thanks for the pointers, Guys.... Ill let you know what works best...
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
