Go Back   Offshoreonly.com > Technical > Fiberglass and Paint
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 09-22-2009, 12:13 PM   #11
93, 32 fountain fever
I found this product called crown $15 for a gallon.... Removes everything, made for rv's & boats
jmoore1225 is offline   Reply With Quote
Old 09-22-2009, 10:27 PM   #12
fountain4play's Avatar
Nor-Tech 3600 SuperCat, 2006 280 Sundancer
Quote:
Originally Posted by Jassman View Post
after the stern is 100% clean. Two coats of the Leverage polish sealer will help from keeping the stuff off. Put Leverage on the drives, steering, rams, and exhaust tips. I always keep like a large sponge in my boat and when rafting up I would quickly wipe off any residue, which made it super easy, most of the time hose off when I put it on the trailer or lift.
Jeff, come on up to LOTO this week and I'll let you show me how to do it correctly....
I've bought Leverage, it seems to work pretty good but I need an expert to show me....
"Life's tough. It's even tougher if you're stupid."
fountain4play is offline   Reply With Quote
Sponsored Links
Old 09-22-2009, 10:36 PM   #13
The 539 Hammer
Mastercraft240's Avatar
BOATLESS
The best quick fix you'll get on a daily basis is Greez Off. Hose your boat down, cover the transom with greez off, let it sit for 5 minutes then wipe off with the rag and spray it down again. Worked for me everytime. Leverage oxidation remover works well as well.
Mastercraft240 is offline   Reply With Quote
Old 09-24-2009, 12:35 AM   #14
Rebel_Heart's Avatar
Fountain - 2001 35 Classic
Great ideas. I'll give some of them a try.
Rebel_Heart is offline   Reply With Quote
Old 09-24-2009, 07:12 AM   #15
Jassman's Avatar
Thanks, Id love to, but this weekend will be the first PR I've done this year...Patriot Run in LA...Catching a ride with a buddy......Just remember wax on..wax off... to keep that good lookin paint job of yours looking great. Catch you next year.
http://compmillennia.com/
Jassman is offline   Reply With Quote
Old 09-24-2009, 09:09 AM   #16
382 Fastech
Simple green, simple
fossil fuel is offline   Reply With Quote
Old 09-25-2009, 11:53 AM   #17
Geronimo36
Panther's Avatar
36' Apache
Quote:
Originally Posted by Strip Poker 388 View Post
Thats the reason I had mine painted,The sides would get the scum/sooot line also,On my sides all it took is soap and water,Painting the transom, will be the same as the sides.no more harsh cleaners,
Rob,
Painting mine has helped a bit with the clean-up. Also, no more iron stains on teh transom at the end of the season... I found if I clean it as soon as I get back to the dock it stays clean.
The last weeks I used the boat I was in a rush and didn't have time to completely soap down the transom so the soot dried and I coudln't get it off with soap/water or spray-nine. When I got the boat back to my house I waxed it and it all off and cleaned up nicely!
One thing I noticed is the paint "show's" soot a little more than the gel did but that may be because the paint is much shinier than the gel was back there. In hindsight I would have painted the transom a dark color.
Geronimo!!~
Panther is offline   Reply With Quote
Old 09-25-2009, 03:09 PM   #18
white wall tire cleaner.. Dad's PQ had 496's and it was black everytime we pulled it out, white wall cleaner was the only thing we found that worked easy.
show-n-go h2o is offline   Reply With Quote
Old 09-26-2009, 02:14 AM   #19
32 Active Thunder
You could try using some Gel Gloss. Its a bathroom cleaning product that also has wax in it. Its great for cleaning fiberglass showers and onyx sinks. You have to wipe it or spray it on and then wipe it off. a freind used to use it on his boat all the time.
Clorox Clean UP is also a great grease and soot cutter. You can just spray it on and scrub a little and rinse off.
Griff is offline   Reply With Quote
Old 09-26-2009, 07:35 AM   #20
1999 Donzi 22 C
Spectro XL-1 motorcycle wash. Soot melts off and doesn't bother the wax.
Also works well on removing the brake dust on my trucksaluminum wheels.
Ken
minxguy is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
