Go Back   Offshoreonly.com > Technical > Fiberglass and Paint
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 10-01-2009, 03:18 PM   #1
gel-kote repair
Hello,
I have a 10"x10" area that needs to be have new gel-kote put on . The area is sanded and I applied a coat via a roller. I going to wet sand it smooth but which is the best way to apply the final coat. Any suggestions would be helpful. Thanks Jp
alecsammy is offline   Reply With Quote
Old 10-01-2009, 09:46 PM   #2
Neno the mind boggler
glassdave's Avatar
Batboat, 38 Donzi ZX, 16 Sidewinder, 10' Zodiac and a ScarabIII
you will need a waxing agent or Duratec in the final coat to make it sandable. Its best to spray it with a Duratec gloss additive but it is possible to roll it on with good results. Where is the area at on the boat?
08 OPA High Points Champion
glassdave is offline   Reply With Quote
Sponsored Links
Old 10-06-2009, 11:32 AM   #3
glassdave's Avatar
Quote:
Originally Posted by SUE C Q View Post
Now this is old school but why not buy a pre valve to spray your gell with and i think the price is around two dollars and a half and it would be nice to know the area that need's to be sprayed because you just might not need to buy anything else other then Acetone .
I use Pre Vale's all the time. They are great for small touch ups. 10 x 10 is pushing it but yea its certainly do able with the little pre vale unit. Good idea. You should be able to get away with just a waxing agent and acetone. Alecsammy what part of the country are you in?
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
