Go Back   Offshoreonly.com > Technical > Fiberglass and Paint
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 10-24-2009, 12:17 AM   #1
Question for GlassDave: Crushed Glass Media Blasting
I'm in the middle of tearing out rotten stringers inside a 22 ft boat. There is a very heavy gelcoat build up inside of the boat that I want to get off but is turning out to be difficult with my grinder. I talked to a soda blaster and he said that the soda probably would not do a good job stripping the gelcoat. He recommended crushed glass blasting. Is there any issue with this, i.e. will having crushed glass residue in the boat have a negative effect on my laminations when I build it back up?
IHTFP is offline   Reply With Quote
Old 10-24-2009, 10:11 AM   #2
Glass wont remove it get 24 grit grinding disc installed on 10,500 4.5 inch angle grinder , not much stopping that set up
activatorf1 is offline   Reply With Quote
Sponsored Links
Old 10-24-2009, 10:18 AM   #3
Neno the mind boggler
glassdave's Avatar
Batboat, 38 Donzi ZX, 16 Sidewinder, 10' Zodiac and a ScarabIII
i agree blasting wont cut it and will most likely be a pretty big mess to deal with. You need to get industrial quality grinding disks of at least 24 grit. Unfortunatly its the only way. I would use the larger disks though and a grinder in the four to six thousand rpm range.
Trust me . . . if there was an easier way . . . i'd be do'in it
08 OPA High Points Champion
glassdave is offline   Reply With Quote
Old 10-24-2009, 10:49 AM   #4
Thanks, I have been using the grinder method and it definitely works it is just tough work. I thought there might be an easier way.
Old 10-24-2009, 11:19 AM   #5
There is a much easier way , hire two Mexicans @ 5.00 per hour and go inside and watch Sanford & son
Old 10-24-2009, 11:56 AM   #6
Where's the Beer?
J-Bonz's Avatar
Location: Cleveland, OH -->W/Extended stay in JohnsonCreek, WI
Cigarette, 38 TOPGUN & 21 Apache Scout
Quote:
Wow, everytime I get go to grind that is what I am thinking....................
Just B-Dock'n it.......
J-Bonz is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
