OffshoreOnly Boat Classifieds Sale
Go Back   Offshoreonly.com > Technical > Fiberglass and Paint
Register Upgrade/Renew Membership Forum Rules Search Today's Posts Mark Forums Read
OSO Sponsor
NorTech
OSO Sponsor
NorTech
Advertiser
Advertiser
Thread Tools Search this Thread
Old 10-27-2009, 04:21 PM   #11
32 Active Thunder
Here is a link for Lonseal
http://www.lonseal.com/products.cfm
Griff is offline   Reply With Quote
Old 11-01-2009, 02:16 PM   #12
staysHARDbeatIT1moreTIME
1979 24' Pantera
911 ! Started glassing , 1 layer of cloth dosn't look thick enuff ! How many layers should I put down ?
Do the layers have to be laid wet on wet ?
What if it tacks up before I put down a second ?
If it stays HARD beat it one more TIME !!!!!!
OCCJoe is offline   Reply With Quote
Sponsored Links
Old 11-01-2009, 04:03 PM   #13
Slippery when wet!
1.What are you using for the glass Fabric? 2.how are you Measuring the MEKP 3. What kind of resin are you using .4 The Temp where you are working .5. Do you precut and fit before lamination.
We always Back wet the surface that way the resin comes up through while you roll the glass down with a metal roller.
Steve 1 is offline   Reply With Quote
Old 11-01-2009, 04:53 PM   #14
1979 24' Pantera
Thanks for responding but I didn't want to chance it so I put a second layer down before the first dried . I used 7.5 oz clear cloth , seamens choice resin mixed 1.5% its about 70 degres here and I did precut the cloth before I started .
And god bless all who do fiberglass work for a living !!!!!!!!!!!!
Old 11-01-2009, 08:46 PM   #15
serious sport for serious people...
you need to scuff sand , wipe with acetone, then you can lay down the next layer
phragle is offline   Reply With Quote
Old 11-01-2009, 09:14 PM   #16
1979 24' Pantera
GLASS Work is done ! now I want to top coat it with 2 part white and maybe put lonseal down !
Does anyone know where I can get the lonseal the looks like diamond tread ? ( small quanity ) !
Old 11-02-2009, 04:58 AM   #17
27 Kryptonite
http://plasteak.com/osc/index.php?cPath=1_30_76
jdub is offline   Reply With Quote
Old 11-03-2009, 11:55 AM   #18
1996, Fountain, 27ft
Show us some pictures!!
Fountain Family is offline   Reply With Quote
Old 11-03-2009, 02:49 PM   #19
1979 24' Pantera
Quote:
Here's the floor after I fixed the imperfections in the plywood with duraglass and prefit the the cloth . As you can see I tore the boat all to hell , Updating whole cockpit and cabin .
I'll have more later with the resin down !
Old 11-12-2009, 11:16 PM   #20
nice job
I do glass and paint work for a living and just caught up to toyour project. Great job and I admire anyone who takes on a project of this type. Just wanted to add that you have a good idea to seal the glass with paint or gelcoat. while resin and glass hold water in or out very well it is by itself a porous system and your paint will give you the moisture protection. the gelcoat in the mould isnt just to make the boat pretty. Great job!!
scottnbebe is offline   Reply With Quote
Search this Thread:
Advanced Search
vB code is On
Trackbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
Copyright 2008 OffShoreOnly. All rights reserved.
