Go Back   Offshoreonly.com > Technical > Fiberglass and Paint
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 11-16-2009, 07:50 PM   #21
staysHARDbeatIT1moreTIME
OCCJoe's Avatar
.........1979 24' Pantera ......... .........07 Y2K Superboat...... ......30' Cobra Predator cat.....
I need to change my name to OCD Joe because I never stop , I sanded the gunnals down (8hrs) to remove carpet glue . Cut the storage compartment out from under the seat and built speakers box's and glassed them for the 6x9 's and the 12" sub .
The floor has two layers of 7.5 oz cloth . Don't like the clear resin wish I had used the green that the builders use !
If it stays HARD beat it one more TIME !!!!!!
OCCJoe is offline   Reply With Quote
Old 11-16-2009, 10:47 PM   #22
Rookie's Avatar
30 Scarab Panther
Looking good, I did the same job last year. Glassed and painted the floor. A lot of work.
No matter how pretty she is, there is a guy who is sick of her S#!t
Rookie is online now   Reply With Quote
Sponsored Links
Old 11-22-2009, 11:15 PM   #23
OCCJoe's Avatar
Ok ! Why is it so hard to get the bubbles out of the glass (matt) on the corners and edges ? I roller, roller , roller and wet and brush and pull but the bubbles keep coming back !
Whats the tricks ?????????????
Old 11-23-2009, 01:15 AM   #24
phragle's Avatar
Offshore medical and safety
glass doesnt like 90 degree bends, thats why you radius the tops of stingers etc.... once you roll the bubbles out, try wrapping something heavy with a square edge with wax paper and laying it in there to put pressure on it while it kicks,, might work..might not but worth a shot..
Screaming Beaver Yacht Club
twin 188 hp monster 5 liter motors, 1288 hours on the meter propelling a 30 year old resin bucket at ballistic speeds... 47.8 on the gps!!! one bad mofo. seriously.
phragle is offline   Reply With Quote
Old 11-23-2009, 08:22 AM   #25
Charter Member #232
Audiofn's Avatar
1979 Formula 302
You could have radiused the inside corners with cabocile. The cab helps to hold the glass down.
God is my Co-Pilot..... but I hit a mountain and had to eat him.
Audiofn is offline   Reply With Quote
Old 11-23-2009, 10:17 AM   #26
Neno the mind boggler
glassdave's Avatar
Batboat, 38 Donzi ZX, 16 Sidewinder, 10' Zodiac and a ScarabIII
you should be able to work mat into just about any corner. Try rolling toward the corners pushing the laminate into it. Another thing you might try is mix just a bit of cabosil in the resin.
08 OPA High Points Champion
glassdave is offline   Reply With Quote
Old 11-23-2009, 03:24 PM   #27
OCCJoe's Avatar
Yea! the inside of the box's came out great but the outside edges have some lines of air bubbles , I only did the sub box so far but I'm gonna router the edges of the 6 x 9 box's before I wrap them and see if that works !
What is cabosil anyway ? ? ?
Old 11-30-2009, 12:27 AM   #28
OCCJoe's Avatar
Kool ! Thanks for the info , I took a grinder and rounded the corners ( Just took the sharp 90 off ) and the glass wraps around it nicely now.... post pictures of the speaker box's wraped and gel coated in a litle bit !
Old 11-30-2009, 02:53 AM   #29
phragle's Avatar
its a filler, like making gravey, add more flour and it gets thicker...
Old 01-11-2010, 02:57 PM   #30
Boatless for now...
So did you get the floor finished up? If so its about time for some pictures! Sounds like your doing a good job.
Brandon is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
