Awlgrip is considered a "Topside paint". It is the most used marine paint in the industry, but does not stand up to prolonged water exposure below the waterline.
If you plan on leaving your boat in the water for a few weeks again, you really need to have a
bottom paint on the bottom. Bottom paint is not as pretty as topside paint, (at lot less sheen, and fewer color choices). What color boat do you have?
If you want to try to minimize the appearance of bottom paint, just scuff sand the paint with 80 grit and apply a couple of coats of
white bottom paint.
If you plan on leaving the boat in the water most of the time, I would recommend the added step of a
marine epoxy barrier coat primer before applying the bottom paint.
If you are in fresh water, then you don't need an expensive bottom paint. If color does not matter, I would go with a
cheap bottom paint.
