Gelcoat and graphics repairs
I need to have a few spots repaired on my outlaw, the prev owner sanded part of the graphics off of the lower part at the rear of the boat. The starboard side also has a fairly large spider crack that needs fixed. My questions are: Can I fix this myself? and if so how would I do it. If I can't do it myself, what's this gonna cost to repair?
Thanks for any help
Thanks for any help
Lakeside Restorations.com
Commercial Member
We have fixed stuff like that before & worse. Unless you feel you can blend very well & you have done stuff like this before. It is probably best to have a pro do it. You appear to have a good amount of oxidation as well. It may need to have the graphics redone. There may not be enough material left to bring back the color in the rest of the graphics. I would expect it is going to cost more than a few hundred bucks if it is getting fixed correctly.. Also you may want to consider fixing the cracks & body as needed & having the sides completely painted and side step the whole gel graphic thing.. Just a thought..
Hope it helps. If you are interested in our services we are a a couple states north of you, but here if you need us.. Jamie / Lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
Thanks for the advice! I had hoped to try my luck at it and could probably do the paint work ok, but that big spider crack makes me think that it's over my head. I also don't know how well I could get the new white gel to match the existing. Anybody know a good shop in Louisville, Ky or Cincinnati,OH that will do this? I need to get someone to quote it, but the 2 I have called only do cosmetic repair in the winter...
