Imron Paint Question
Hey Glass Dave I did precisley what you suggested regarding dry sanding with 1000, then stepping up to 2000 wet, I did have a problem with the 3000 not sticking to the pad. So I skipped it and went with the 4000. Then I went to a fine compount Finsesse it II. I also experimented with some coarser compounds but the finesse it II did the job after two cuts with a white foam pad.
It made an okey job, with some orange peel look really professional and like glass.
I need to thank you for your knowledge and willingness to share it on this forum. I personally love to share information if I can help anyone that is interested in boating.
Thank you once again
Brian
Brian
