Go Back  Offshoreonly.com > Technical > Fiberglass and Paint
installing new stringers ??? >
Old 08-26-2010, 07:51 PM
Default installing new stringers ???
Hello,
I'm installing new wood stringers, what type of bedding material is needed to keep the stringer off the floor and how much of a gap should I have. Any installation details would be very helpful. Thanks Jeff
alecsammy is offline
Old 08-31-2010, 05:21 PM
scippy's Avatar
Originally Posted by alecsammy
Hello,
I'd like to bring this to the top.............ain't nobody got an answer for Jeff................Dave???
scippy is offline
Old 08-31-2010, 07:05 PM
Default stringers
I am not a pro by any means, but what I usually do is cut the stringers to size then glass prior to install. I shim to about 1/2" clearance and then glass a few spots let dry pull shims and then finish it off. Works well for me.
powercat is offline
Old 08-31-2010, 07:16 PM
Registered User
I don't want to sound stupid here but I don't get it about the gap you want. would someone please explain to me what your talking about I am ready to do stringers myself and i feel like i am missing something now.
thanks Keith
donnawanna is offline
Old 08-31-2010, 08:44 PM
Default stringer
The gap he is referring to is the is the gap between the stringer and the hull. The idea is that if you leave a small gap between the two you reduce the chance of stress cracks on the outer hull. I have done it both ways with with no noticeable difference
powercat is offline
