Go Back  Offshoreonly.com > Technical > Fiberglass and Paint
New Project - Need help estimating design and materials >
Old 11-30-2010, 09:20 PM
Charter Member #232
Audiofn's Avatar
2lb is probably what was in there that you took out. Like dave said no way you want to go with 8lb it will cost a fortune. 14 pound you can almost tap it is so dense.
Put your best foot forward!
Audiofn is offline
Old 12-06-2010, 09:30 PM
I finally hit dry wood..... at the dash!
I am going to add a real bulkhead here and start working back. The foam came out in huge 1-2ft pieces until I got to the dry stuff. I used a long piece of aluminum flat bar like a butter knife. I drove it into the foam and worked it to each side to cut large pieces.
Hopefully a full day of sanding and squaring off, and I will be ready to start in the other direction.
Attached Thumbnails New Project - Need help estimating design and materials-sea-ray-strip.jpg   New Project - Need help estimating design and materials-sea-ray-strip-1.jpg
TxHawk is offline
Old 12-15-2010, 04:51 PM
Nice progress.
I saw this arneson drive for sale and your project was the first thing that came to mind. http://www.lakepirates.com/forums/in...0&#entry367526
SLEEPER!! yeahaw.......LOL.
TexomaPowerboater is offline
Old 12-15-2010, 07:04 PM
Crazy Energy
Velocity Vector's Avatar
[QUOTE=TxHawk;3268643]I finally hit dry wood..... at the dash! QUOTE]
Heee!
Velocity Vector is offline
