help with muddy water stains..
I have a white hull boat, and we boat in some muddy water, and its stained the bottom of the boat, a brownish color. Is there anything out there that I can remove the stains on the bottom on the boat.
I picked up a blue gel product called FRS (fiberglass restoration "something") from West Marine on the recommendation of the sales guy. I could not believe how incredible it was. Wipe it on and let it sit a few minutes, then rinse off. Within 30 secs, you can see the brown/yellow turning white. I thought it was just 26 years of old and could never be white. I was wrong. That stuff was amazing!
I have and use Hula Hull Cleaner. It is non acidic biodegradable and can be diluted. Mixes up to 4:1 goes in a sprayer, sprayed on and wiped or rinsed off after 30-45 seconds of dwell time. Can also be used to remove water spots from fiberglass, windscreens and brightwork.
