Removing tabbing, glass??
What tools do you guys use to remove the glassed in tabs and main inner fiberglass of the boat? I have a 4" grinder and 7" buffer/grinder. Ive only been using the 4" with a metal grinding disk as well as a cut off disk. Should I use the 7" with a sanding disk? Thanks in advance for help, I'm still learning.
1 Post
Fixx
George
