How hard is Fiberglass for the DIY??
#31
paint sticks make the perfect spacer for just about all gaps plus they are consistent and readily available.
08 OPA High Points Champion
#33
actually i got my body shop supply guys trained pretty well, they just give me a whole box and a case of strainers whenever i ask. They have the nice thick squared off ones
#37
Yes I will intall halfround weather strip and there will be a drain hole in corner with a hose running intop bilge . I have plenty of time usaully in shop till 3 am and I wont settle for less than perfect . It might kill me yet !!
Larry
Larry
#40
This is the first time over here all my pics are over at Skater and will post from here to spark ideas for others . Here are a pics of the Hidden hinges I designed and built and I cant stand seeing a high doller boat with exposed hinges or screws so I came up with these . I have a month in working these out as the operate with a hidden high speed Linear Elect Act on a 9/16 jack shaft off rear hinge pivot point . They take 3 seconds to open and when open all you aee are hinges , no gas strut or screw jack . Also when I layed up doors I bonded in 3/8 thick alum so I could tap hole from bottom . I aslo designed stainless hidden hinges for cooler door as well and openes with remote electric door lock
