wrap removed
wrap removed
i purchased a 08 donzi zr27 that had a wrap on it.under what would have been the darker surface of the wrap it seems to have opened small pores.these pores may have had a small amount of mold in them. i used a very small amount of bleach along with a 3m cutter and buffed out the surface. then put a heavy wax coating.all seem well until the end of summer and i noticed a return of the dark spots.i would guess i should just have the whole area ground and repaired.i dont think i have enough thickness to use the cutter and buff through it.any ideas
1 Post
fixx
go to donzi.net and look up mr x,he use to work at donzi and he could give you a solid answer..
