Go Back  Offshoreonly.com > Technical > Fiberglass and Paint
glass over a sub box thats mdf ? >
Old 01-05-2012, 11:20 PM
Hey 4bus how bout a product like Coosa or Penske board for an enclosure? It comes in several different densities. Wonder if you could tune an enclosure with this.
http://coosacomposites.com/
Dave,
Looks like the stuff I was cutting into on my friends 388 hustler cockpit walls this summer.
Not really sure, the only way to know is build one and test next to an mdf box of the same size. The speaker world decided mdf was best, the boat world knows mdf doesn't like water. I hbae built sub boxes with clear lexan fronts and did not notice a resonance issue.
Some stuff is too absorbent. I was at the ces show and dynamat had a sub box lined inside and out, the speakers mad very very little sound. So a dense foam will rob you of noise.
Bose uses advanced composites instead of wood.
I'm sure if I was in you shop for a week with a frequency meter we would find the perfect material, or you would create it.
On a side note I put an mdf box with 4 12"s under the back seat of a checkmate that is kept on a lift in 2005. I called him tonight, box has no issues, and he pounds the boat and stereo. Home depot has 1.5 inch mdf that is good quality
4bus is offline
Old 01-06-2012, 09:58 AM
Wow- didnt expect this responce when I posted the question. I have deciced to do more research before proceeding. I have 2 JL 10w5 and may or may not add a 10w7. I saw some boxes @ Waves & wheels that are marine sub enclosures and apear to be plastic. Has anybody used one or have any input.
sparkie124 is offline
Old 01-06-2012, 12:51 PM
Received 1,324 Likes on 739 Posts
We used to make a lot of sub boxes out of sheet plastic, had to to fit odd shapes.
The key is to use internal bracing so the box doesn't vibrate, also a good damping material inside.
We also did some where we would use the foam in place packing to fill a void (in a bag).
Take the plastic off and lay a couple of layers of glass mat, resin it up and let dry.
Then dig out the foam and glass the inside. We did this as we were trying to proto type what would end up as a molded piece in production.
BTW
BOSE= better sound through marketing!
LOL
Wildman_grafix is offline
Old 01-06-2012, 06:24 PM
The perfect speeker box is made of concrete lol very water proof but a little heavy for boat use.
lightning jet is offline
Old 01-06-2012, 10:24 PM
Neno the mind boggler
glassdave's Avatar
BTW
LOL
Yup . . . . . They make some neat stuff but for the money you can get better sound. Wayyy over marketed . . . Kinda like west system epoxy lol
08 OPA High Points Champion
glassdave is offline
Old 01-07-2012, 11:49 AM
BTW
LOL
The reason I used BOSE for an example was to talk about how important enclosures are for speaker performance.
I'm not saying BOSE makes the best speakers out there, or has the best sound. Not even close.
Bose however is very clever at getting deep range frequency response and high spl from little speakers, the speakers themselves are not even high quality when compared to industry standards. They do this using band pass technology and extensive port testing. Using a great speaker is only part of the equation, when you have BOTH you are where you want to be.
I do own one BOSE item. It is a speaker dock for my Iphone that was a gift. I have to say it is quite impressive for it's size, especially when it comes to low frequencies.
4bus is offline
Old 01-07-2012, 09:54 PM
Hey 4bus,
I said that because its a bit of a inside industry joke, yes of course there is much more then the speaker itself.
I also have a BOSE wave that I won at a Northwest Airlines function. Sill have one friend that works as a transducer engineer at BOSE.
I worked at Harman Kardon (Harman automotive), for 12 years, you would be surprised what can be done with a correctly designed enclosure.
No harm meant.
Old 01-08-2012, 03:10 PM
Ginger or Mary Ann?
US1 Fountain's Avatar
Does the shape of the box matter?
I have a free air sub mounted in a side storage compartment door and am thinking about building a box to line the inside to a more idea cu ft size for a correct sub, plus it'd be solid, not the FG lining. To do so would require the box made to fit inside the exiting storage compartment door opening as I don't want to cut it up for future changing back over.
US1 Fountain is offline
Old 01-08-2012, 07:00 PM
Hey Jerry, I can say yes and no on that one. LOL
First I assume you will not be using your free air sub in a box right?
As for the shape, in automotive we made some very strange shape boxes trying to pick up volume, if you end up with a very thin (front to back) box we measured less output for the same volume as a more traditional shape. But I am talking inverted woofers in boxes that were only a couple of inches thick.
If you are going to use a sealed box and have what size it needs do what you can to get the volume, I doubt you will have problems.
Just make sure the box is braced so it doesn't vibrate, and use a good fiber fill to cancel any unwanted reflections.
http://www.sonicelectronix.com/item_...iber-Fill.html
Old 01-08-2012, 09:32 PM
Ginger or Mary Ann?
Correct, replacing the free air. I have 10 3/4" depth to work with. Haven't done the math yet to see what I can end up with for max possible size, considering max possible W x L, and then shrink down if need be to get idea volume. Do you still use the fill for idea box sizes, or only when you are undersized?
