self etching or epoxy primer
I powdercoated this block in my old race boat , took 45 in over to get to 400 degrees . It was a waste of my time as powdercoat shows a ton of orange peel , when scratched it is tough to match . When you get down to it powdercoat is way over rated , I just blast, epoxy prime and paint . I sold my powdercoating business
I do powder coating for small parts as it's easy(for me) and the clean up involves a broom. I'm doing all the brackets, valve covers, etc in flat black. Just did all my steering components on my sled this year and I really like the flat black.
Even with my oven pre-heated to 450 it took 45 to an hour to get to 400 . It was a waste of my time . Powdercoat really is crappy finish shows a ton of peel and almost impossible to touch up .
Powdercoat is perfect for production parts and 9 times out of ten whoever powdercoated didnt prep the part correctly
1 Post
Fixx
you can but that is not they way its done in business as there is no way to limit how much powder goes on and too thick it chips . Powdercoat is best used on plant hangers that get bent , washed powdercoated then in a box in 15 min . Ever tried to remove powdercoat ? Either a burn-off oven or chem strip then blast , F all that blast , epoxy , urethane and your done .
