Need glassdave to look at this crack I just found in my hull
get your hands on one of these or even a cheapie one from Harbor Freight. Only way to make short work out of removing core and good clean cuts and corners. This is one of those tools i thought was pricy till i got one, not sure how i got along without it.
http://www.ebay.com/itm/FEIN-FMM250S...item1c26cd64b8
08 OPA High Points Champion
1 Post
fixx
Here is what we found once the inside of the bilge was cut open. The dry wood is where the crack was on port side. What is strange is that even the wood directly above the crack was dry. All of the wet wood is on starboard side opposite of the crack and appears to be isolated to the bilge. He's got some more grinding and cutting to do but should be done by Thursday.
I've already got a dremel multi max, same as that tool but dremel brand. Wouldn't attemPt to cut a boat apart without one. Used it to cut the floor and forward stringers out two years ago
I hired The glass work out and it will be done Thursday. Im Putting the engine back in Saturday. I would have liked to addressed a few more issues while it was cut apart but I'm gonna save some cash and redo the transom and bilge area over the winter. I've decided I can fix a lot of sh!t for what it would cost to replace it with a newer boat so I'm just doing a little at a time. It's not worth what I have in it but I enjoy it and it keeps me busy.
