Laminate thickness question?
Well, I figure either rebuild the Motor Mount, or add a peice of plywood to the striner I already built. By the way the stringer from the bulk head back to the transom is already 1 1/2 thick ( 2 pieces of 3/4 laminated together), thats the way it was from the factory. another 3/8" surely would be a strong core.
Its easy to get drawn into the hype of epoxy, its fantastic to use but far beyond what many of us really need and many times not worth the hassle. I cant say anything bad about the process its just over marketed in my opinion. The reason why stringers and transoms fail 99.9% of the time is not because of what was used but rather how it was used.
08 OPA High Points Champion
Thanks Dave, Youve made my mind up Im going to make up the differnce in the mounts, Im happy with my decision to use epoxy, somehow I just feel better about it. must be a mental thing.
Thanks to everyone who responded to this thread.
I will apologize now, cause obviously i am a moron when it comes to this....but uhhh what to you use to secure the stringer to the transome and to the bottom of the boat? i re-read over both pages here and every bit of that was greek to me...think i followed the ply wood part and yeah i was lost..
I have been recruited to help out 38 X with his fiberglass work, lol.
He has a hole that is rotted around the edge. Would it be okay to cut out all the rot and fill in the hole with a 2 part foam and then use 2 layers of polyester resin and 18oz E-Glass? Or should we fill in the hole we cut out with layers of plywood like is in there now?
