Go Back  Offshoreonly.com > Technical > Fiberglass and Paint
Can non-skid be wet sanded? >
Old 02-14-2013, 04:28 PM
speedboatr's Avatar
Default Can non-skid be wet sanded?
I have acquired a 1987 Wellcraft Antigua that the gelcoat on the deck is sun faded and chalky. My 1st thought was wet sanding but most of the deck is covered in non-skid. Can non skid be sanded?
speedboatr is offline
Old 02-14-2013, 04:39 PM
northernoffshore's Avatar
No it will take the bumps off . Use heavy duty rubbing compound and a buffer
northernoffshore is offline
Old 02-14-2013, 05:15 PM
I have used rubbing compound with a stiff brush and a good amount of water. The water helps to keep it from drying in clumps in the non skid.
Patience...myass is offline
Old 02-14-2013, 06:17 PM
Neno the mind boggler
glassdave's Avatar
soft scrub and a tire brush works pretty good for cleaning and brightening up non skid, i use the stuff with bleach.
08 OPA High Points Champion
glassdave is offline
Old 02-14-2013, 06:32 PM
I was gonna say the same. Or wet scuff it with a grey scotchbrite then rub it with compound.
POWERPLAY J is offline
Old 02-14-2013, 06:48 PM
Never heard of that. I will have to try it when we clean the boat in spring.
Old 02-15-2013, 08:30 AM
speedboatr's Avatar
Thanks for the info guys! Starting to clean the boat up in a few weeks and have never messed with non-skid that is chalky before.
Old 02-17-2013, 09:35 PM
romie's Avatar
Bleach with oxy clean does wonders.
romie is offline
Old 02-17-2013, 11:57 PM
Muriatic acid. Mix half water half Acid. Scrub with a tire brush.
Forget the Buffer.
LOTOWONTOPGUN is offline
Old 02-18-2013, 02:12 AM
Default fixx
wet comet kitchen cleanser and a wool buffing pad works good too,,also removes oxidation.
FIXX is offline
