Ppg delfleet evolution
Has anyone used this paint before its a polyurethane single stage. I was just wondering how it might compare to some of the other paints out there. And I am aware of the dangers of using polys, I just have a lot of it left over for a past paint job and was wondering about using it as a marine paint, topside of corse
thats some bomber stuff, likes to be laid down "as sprayed". In other words try and get it as clean as you can. I dont think it likes to be buffed. It is very durable.
08 OPA High Points Champion
Yea it's some tough stuff used on a drill rig a couple of years ago still has a good shine still and it's bin exposed to some nasty stuff, rig has Olny worked on hazmat sights. To get to the point I was going to use this on the hull sides so at rest some will be underwater it is a trailer queen thus far it's never spent more than10 hrs in the water at any time will be spraying it over interlux epoxy coat primer any problems with that?
It is equal to PPG concept line of single stage, very durable and holds a great gloss. The clear coat in this line is great it is equal to PPG Global 890 and great on boats!!
I would think you would be fine on an outdrive, Im applying some to a Bravo XR drive in couple of weeks IF IT WILL WARM UP that is! Make sure you use a self etch primer if there is bare metal. Don't mean to sound like a know it all jus offering advice!
