Powder coating
What are you thinking for colors?
If you find a guy that does industrial/commercial powder coating he can usually put your parts in the oven with a bunch of other parts of the same color. Lots of these guys doing these big commercial jobs are always doing black, white, red, etc. I think a lot of the cost is in the fuel to run the ovens and prep if you want them to strip the parts. The powder isn't very expensive and very little labor to spray them because it doesn't take the time and precision like liquid paint. He just points the gun at the part and the paint is attracted to the metal like a magnet!
I'm just looking to do like 10 pieces white.
http://www.qccoatings.com/
This place is just of 23 mile in Macomb Twp. I have been using them for years for custom harley parts and boat parts. They did the headers on my jet boat in a high luster chrome look. They looked perfect after two years of not so gentle use. They should be able to ball park it over the phone for you.
That was my next question, to sand or not. A light sanding with fine grit?
Powder Coat
White is a single step job which is usually very cheap since food industry equipment is regularly done this way. If your pieces are small it's very easy to do in an oven you never intend to cook food in again.
I had translucent 2 stage pieces last spring that were mostly done correctly locally. They missed the timing and the base (chrome) hardened a little too much, so it was redone. On a single stage, a rough base with proper base preparation, this stuff is very durable.
