Bottom of hull paint?
What paint or paint/clear do you guys use that holds up to the bunks on the trailer and being under water all day.
I was thinking DuPont polyurethane that I have used on vehicles but not sure if it will work on the bottom of the hull as for toughness/durability.
I guess gel on the bottom and poly on the sides and deck? If you use gel do you use non wax untill last coat then use wax?
1 Post
theirs a number of ways..you can spray non wax until the last coat ..or you can mix duratec clear into the gelcoat and make several pass's ,,this way makes it easier to sprap and it goes on alot smoother and makes less sanding..
1 Post
you can try ferro corp in plymouth in or to pay a little more and call minicraft in fl..mini will have factory pack colors to match your boat..http://www.minicraft.com/
