Sealing holes drilled in transom/hull
I will be adding external steering this winter I need to drill holes for brackets and hose fitings. After I drill the hole I want to seal the wood with a paint or gel cote before I run bolts or hardware through the transom I will seal bolts and hardware with a silicone sealant I just want to make sure exposed wood is permently sealed if silicon fails. My question is what are people using to do this with the best results and longevity
