Deck project help
you can do both it all adds to print control. the ounce and a half will go a long way towards that you should also use gel coat on top of that or Duratecs VE fairing primer
08 OPA High Points Champion
Sounds like a plan. As long as there's no limit within reason of multiply priming and blocking I will get it. I assume the faring primers are a two part primer? I look forward to the detailing/prepping for paint. Just getting this glass work out of the way I will be happy. I worked at a body shop throughout high school and as a hobby painter off and on over the last 25 yrs or so however this project goes far beyond anything I've tackeled.
Glass Dave I cked on the suggested primer. From what I read up on it sounds like an excellent product. While doing search I found a few different Duratec VE primer product #s. Not sure if it was just colors etc however can you post correct number for me. Just wanna make certain I get the correct product. 1799-006 was one I came up with. Also do you use catalyst with? Also where to purchase...
Tks again
John
Tks again
John
Tks again
John
I almost stopped posting as I assumed the majority didn't see it as a worthy project. I will post a pic of the original if I can find one.
Thanks. Like the new look.
Just got the VR1 back from the Marina. The dock annd lift is in and after a day of cleaning and waxing will hopefully throw in in the water tomorrow. Still have to install the new bigger pull up cleats but can do that while it is on the lift.
Please keep the pics and updates coming.
Padraig
Padraig
