Oxidized gelcoat voodoo?
Please keep us posted of the long term results. Find an older red boat for your best example.
I am interested if it proves to work. I do gelcote repairs and buffing on the side for a dealer and other word of mouth customers.
It depends where I'll be working. We have a number of them. Specialty smaller and high end polishers, Porter Cables, Flex 3401s, Meguiars and even some Harbor Freight ones. Today I'm using my Harbors because I'm working on a boat in the water and if they slide off and fall in the water it's no big deal! I have a huge selection of pads because a lot of our work is on the road and you never know what you'll run into. My favorites are the Meguiars microfiber cutting pads and the Lake Country purple foamed wools. Both cut extremely well and leave a great finish.
The best polisher for gel is of the pneumatic kind no brand specific it just needs to have some killer rpm and just losing all the weight from an electric buffer is more than enough reason to go out and get one. Trust me u will be thanking me if u make the change !!
Applying acid to chalked gel will remove most of it and it will not harm the gelcoat. If you think you are going to try and make me believe that you just got rid of chalk and applied one easy step to obtain that gloss you are sadly mistaken. If that is the case you have spent good time polishing and I mean hours not minutes. If u buff on gel long enough without burning it yes it will eventually polish very nicely.
S'cuse my skepticism Vc and am sure you can understand it given this biz . . . . . buuuuut i gotta see this first hand . . . . . . . . when can i get samples?? actual product?? . . . any info other then pics of results (again sorry for my skepticism but . . . well you under stand. I'm sure you been there done that as well )
08 OPA High Points Champion
