Gel Coat in bilge
Gel Coat in bilge
Just had new transom put in and the shop gel coated what they replaced. I purchased more waxed gel coat and harder from transom shop and mixed and applied as told to the rest of the bilge. After 24 hours its hard but tacky. Tried a heat gun to a spot and became more tacky. Does it need more time? What do I need to do to fix this if there is a problem?. Also will cured gel coat clean up easily from dirt and oil or will stain?
waxed gel can still be tacky, its hit or mis I've had some brands dry as a bone and others still tacky. If I'm ever in doubt i PVA it its a guaranteed cure. If your goal is a gloss gel finish best bet is to build up in waxed or pva'd gel sand down and use a Duratec/gel blend for final coat.
08 OPA High Points Champion
yes you can sand the waxed gel with 80 then with 180 and top coat it with a 50/50 duratec-gel mix with no wax.
Do not use Duratec in your gel for your bilge as that is not what its used for. You most likely over catalyzed it which will cause it to remain sticky and for that matter there is at least a half of dozen other reasons why it didn't surface cure so without knowing what exactly u did I cant give u the reason. U mentioned heat gun to which was the worst thing u could possibly due to try and make it cure as all that does is flash the catalyst out of the gel. It sounds like u must be dealing with cold temps an if that's the case u should have used a heat lamp (with caution) if u didn't have any PVA. What u can do is get yourself a gallon of acetone as well as a few good sized rags and soak the rag and wipe one direction across from one side to the other then give it a few and see if u need to wipe again. Remember to use a clean rag each time because if u don't all u will do is keep wiping the same sticky **** right back onto it !! I have never had any problem with waxed gel not surface curing but I will tell u right now Do Not Use the Duratec in your gel for your bilge. Don't get get me wrong here I love Duratec and Im good friends with the guy who formulated and makes that stuff. Whenever u use Duratec u have to sand it once it cures and let it sit for a day once sanded and unless u plan on sand and buffing your bildge u really should just catalyze gelcoat and apply it anyway u want and then spray with PVA and don't mess with it until the next day. The next day go in with a bucket of slightly soapy water and sponge and scrub the green until its gone and u will have shiny gelcoat. If u use wax (surfacing agent) the gel will not cure shiny and u will be in for some serious work to make it shine. I hope this helps u if u have any questions feel free to contact me.
Duratec should never be used where there is potential for water as water is the enemy for Duratec. as it will turn the gel cloudy and flat and sometimes the gel just loses its bond Its a great product don't get me wrong here as it has its uses and why would u put Duratec/gel in your bilge?? It sounded to me like you wanted the bilge area to be as nice as the rest of the boat so if not worried just refrain from wondering about sanding and Duratec.
