Awlgrip on outdrive?
Any reason not to use awlgrip on an outdrive? I would think it would be the best thing to use... I have some awlgrip epoxy primer i got for free so I figure il just order a quart of jet black awlgrip and be done with it.
I used a couple spray cans of Rustoleum Black Appliance Epoxy. Primed any bare areas with etching primer. Has held up amazingly well over past several years.
The rattle can paint now is a low voc acrylic not as good as it used to be it seems but still decent. Almost impossible go get down nicely from the can though.i usually just take freon can tap extract it and lay it down with a real gun at 15psi with a small tip . The el cheapo walmart gun someone gave me works best with that stuff 3 part single stage is better if you can find it in phantom black .
Sandblast the drive to get rid of all corrosion. Use the Mueller green primer that they sell at most Merc dealers. Put on 2 coats of Phantom Black within 20 minutes.
Run it, it will last forever. It is all in the preparation. You do a crappy job it wont last. If you do a good job, it will last a while.
Mine blisterd around the upper water pickup. I assume it was from the inside out and it wasnt that bad. Again, its all in the preparation.
My 1992 Mercury 200 outboard is almost all original paint and still looks great. Of course it's run in 100% fresh water too. But, if you scratch the factory paint and get through the primer - especially of you run in salt water - you're all done as the corrosion will continue to creep under the good paint.
I should note that my gear case was repainted (in Imron) almost 20 years ago and still looks awesome.
