epoxy hull?
epoxy hull?
As the title states I just found out my boat is an epoxy boat, what if anything does this mean in terms of care and maintenance, if any? Sorry this is probably a stupid question to most in the industry.
I have to agree with griff, I would be very surprised if it is epoxy. was your boat a custom build for someone?
if it is epoxy, the biggest consideration is if you need to repair anything. It must be done with epoxy only and prep is critical. At that time builders were still experimenting with gel and epoxy so its possible. the super v that Wahoo had was an epoxy boat with gelcoat (that came off in sheets
08 OPA High Points Champion
Boat images were put on Facebook by R3. He said it was an experimental epoxy boat with a blackhawk drive at the start of it's life. Bravo boat now I do believe if I followed the discussion on the image.
Correct, you all know as much or more than likely a lot more than me .
man you guys are fast I edited my first post and hafta do it again lol
