Drilling thru gelcoat
Lots of excellent replies. Thx guys!
I like the idea of starting out in reverse. Makes good sense.
Is it OK the use the brad point drill bits with a small pilot hole?
If I drill from both sides I'll definitely need a pilot hole.
Not sure yet how good the access will be from the bilge.
I may have to drill from the outside only.
It's pretty straight forward and you don't need any special bits other than a sharp one!
[ATTACH=CONFIG]552129[/ATTACH]
I took the advice of running the bit ( or hole saw in my case) backwoods for the first 1/16 to 1/8" depth. I also put blue masking tape to help protect the gel. Came out PERFECT!! I was even surprised.
I relocated my fuel gauge off my dash.
You rebuild the hull? What speed were you running with what power? What you hope for speed when you get it dialed in?
It's pretty much all been covered but an extra bit I've learned over the years with holesaws is once you've drilled your 1/4" pilot hole use a piece of 1/4" round stock in place of the drill bit on the holesaw arbor. This eliminates the wobbly hole effect because with a drill bit in the arbor it's trying to dig the entire time. With the 1/4" round stock it'll keep the hole a perfect circle.
