Rup Rail Baja 272
Hey guys
I have a question where can I order steal insert a new RUP rail and the matching stainless for my Baja 272? I'm pushed against a wall and both make vinyl and stainless steel are damaged. the manufacturer should be Taco metals. is this right here? Thank you and sorry for my bad English |
Tacomarine.com also contact baja. They may even be able to tell you the model number of the rub rail used on that boat. And if it is other than taco they will know the manufacturer. Good luck.
The only place I was able to source the lower RR molding for my '96 302 was here 877 287-6707, Taco no hady. So if you strike out give Alan a call. His website is rubrails.com
I can also vouch for Alan at Rubrails....he has been doing it for a long time.
