Re: getting back my original gelcoat
It sounds like he used a DA sander. If the grit he used is not to heavy you can get the finish back. You have to figure out what grit he used and sand the bottom with lighter grits until around 600 to 800 grit sand paper. Then buff the bottom with a heavy cut compound then a medium compound and finish with a light polishing compund. Then some hand wax and your ready to go. To bed that is, Its murder believe me I did it last spring. The worst part is your laying on your back reaching up to to the job. I blocked the bottom with 600 wet sand. Water driping all over me and reaching up with that heavy buffer stinks. But is worth it in the end. And gel coat is so easy to buff compared to car finishes.
Russ
