Re: Smartcraft SC5000 Install on 370SS
You need to set the port engine location to port. It seems like it is set to starboard. that is why port engine also shows data for starboard. You should be able to set the engine location with the SC5000.
There is a 3 pin connector "multi engine power disconnect" where the blue can cable plugs in to the engine, unplug and cap this for the port engine. this will keep power from backfeeding through the junction box to the other engine. If this was plugged in. Be sure to check the fuses for both motors, as one may be blown from having the two circuits hooked together. When you are setting the engine location, be sure that only the engine you want to set is keyed up, otherwise, you will set both of them. If the multi engine power disconnect is hooked up, both engines will come on with either key, and you will keep setting them both to the same location. You will have to hook up the multi engine power disconnect for whatever engine you want to set the location on (so it powers the SC5000), and unplug the other one, that way only one ECU is on at a time. Hope this helps!
