Installing under the platform swim ladder
Toxic FORMULA
Re: Installing under the platform swim ladder
I got the ladder from Boat US/West Marine. Yes , a friend of mine who used to be a machinist made them from 1" stainless stock.
After a number of years of searching this was the widest ladder I've found. The 4 step is wider that the three step because the add the forth step to the top and of course its larger in diameter.
Originally Posted by masi242
I put a new ladder under my platform an just screwed it in. It took 12 good size screws to attach it`s not going any where. I have had my platform off thier is no way to get in that section.The platform was made in two sections bottom half and upper, when they put the holes in they glassed in nylock nuts to hold the small bolt that would run up thru the platform. I just moved mine to the other side.
NO WAKE ENFORCER
Originally Posted by 1987-242SS454
Masi is that aftermarket exhaust on your boat?
OH YEAH LOOK UP HIS THREAD AND VIDEO, SWEET SET UP WISH HE WOULD MAKE ONE FOR ME.......
www.putfile.com/masi242
I see the water draining out of the platform...Is that piped through the platform or is just through the platform like the factory setup? It sounds good!
Yes it is piped all the way, when the exhaust exits the transom it dumps into a stainless then into the pipes. The water you see coming out of the platform comes from holes I put in the .s.s box, then I drilled holes in the platform for extra drainage
Thanks 88 so far so good
