If you have a 97 312 then yes. I removed the entire box on my 98 312 last winter. Wife was pizzed that it was going to be too loud but she never realized the difference unitl the second run in the spring when i pointed it out to her....she never noticed! I could hear it, a deeper rumble but not significantly louder. (stock 502 mags, stock exhaust)
Mine is not gutted but has 3 inch diameter holes in both bottom corners and 2 in the center . This makes the boat illegal per SAE specs (113 dB). It still wont hold enough water at idle to muffle the noise. 502 MPIs in a 311.
Chesapeake Bay Powerboat Association www.cbpba.com
I think he's talking about the newer style "box" that fits under the swim platform, not the older SR-1 type that IS the swim platform. (See 97 312 in his profile)
The baffling inside doesn't do much to affect the sound. The muffling that the ST provides is due to water retained inside the ST. If you start cutting holes in the bottom like Insptech did then you're going to start making it louder because there won't be enough water inside to damp the sound.
