SR- 1 Bolster Seat Actuators
#31
Charter Member #232
I am going to look into changing over to Electric this year. Just need time off work!!!! I found a place that makes stainless actuators it should be a very easy swap as long as it has the space for the motor.
Put your best foot forward!
#32
Charter Member #232
If some one can tell me the lenght open and the length closed I can probably locate a ram this evening. Also how far in the pins mount but that is not as important as you can just make a new bracket if you need.
Jon
Jon
#36
#38
Ok so I braved the cold. Well not to bad we hit 30 today. Feels like a heat wave.
The actuator is 12" open from the top to the center of the mounting hole at the bottem and 9 1/2" closed from the top to the center of the mounting hole. The stud on the top is 1 1/2" long.
I took some pics that I can e-mail you if you like.
#39
Charter Member #232
Should be enough. Everyone I was going to snowmobiling with this evening called it early. So I am home alone happy to have a good project to work on!
#40
So... Now two years later. Anyone have luck replacing the manual actuators with electric ones?
And I think there are part numbers for the originals floating around. Are they from avfab? Any guidance would be a great help!!!
