Bell housing help >
Bell housing help
Bell housing help
Old 11-21-2007, 11:44 AM
Thats what happens when the drives are not perfectly even. Some thing has to give. So the the swivel bushings and pivots give.
Latham makes a slotted end for their inner tie bar. Merc used to make one for their steering system years ago.
Jim
MOBILEMERCMAN is offline
Old 11-21-2007, 12:32 PM
Jim
Jim, help me overcome my ignorance. So if I want to add an external tie bar (IMCO, Latham, etc.) I should disconnect or modify the linkage that extends the steering arm to my port drive?
I understand the geometry of uneven tilt/trim. But I never considered how the internal steering would be effected...hmmm.
So a full hydraulic cleans this problem up, and also allows eliminating all that stock steering stuff?
handfulz28 is offline
Old 11-21-2007, 01:49 PM
Michael, The inside steering doesn't know how the two are connected. Either way it steers through the tiller arm and gimble ring on the stb side. You ultimately load one tiller or two. An outside add on system works well and is easy to install. It uses the inside stuff but actuates the outside cylinder instead of the one on the inner plate. Of course the full system is nice but how practical is it.
Jim
Old 11-21-2007, 04:35 PM
I went with a full hydraulic system. By far the biggest single improvement I've made.
sector is offline
Old 11-23-2007, 09:52 AM
Jim
Is the outer tie bar better than a inner? Would it be worth the change from inner to a outter?
MOERON is offline
Scarab28
4
03-30-2006 05:15 PM
nordic95
9
01-06-2006 07:57 PM
Scarab28
1
07-03-2005 11:14 PM
HyperBaja
2
11-17-2004 06:30 PM
Raypanic
16
03-16-2002 11:08 AM
Quick Reply: Bell housing help
